please help me with my problem
Old Jun 5, 2014 | 01:29 PM
brady1929's Avatar
Default please help me with my problem
Recently went from 315/70r/17's to 285/70r/17's and I am having a strange problem. Now when I turn left or right around a corner with my foot on the brake pedal slowing down, my traction control light comes on or the abs comes on. Steering wheel is close to centered. What is going on? Thanks.
Old Jun 5, 2014 | 01:34 PM
LidLess07X's Avatar
How close to centered? That would be the easiest thing on your JK to check and fix. Even if it doesn't work.
Old Jun 5, 2014 | 01:44 PM
Invest2m4's Avatar
Did you re-calibrate the speedo? That seems like the most logical issue. What the computer is being told and what is actually happening are not matching up.
Old Jun 5, 2014 | 01:57 PM
Bypass's Avatar
Has to be actually centered not close.
Old Jun 5, 2014 | 02:33 PM
brady1929's Avatar
It looks centered to me. Also I did recalibrate with my pro cal. Thanks
Old Jun 5, 2014 | 02:35 PM
Mark Doiron's Avatar
Yep. If it isn't exactly on center during test drive on flat surface, expect the lights during certain turns. Adjust, test drive, adjust, test drive until it is perfect.
