teraflex rear track bar bracket
Old Jun 8, 2014 | 10:39 AM
gunbo75's Avatar
So i have had the 2.5 coil lift on for about three years or so and for about one and a half year now the 3/8 inch bolt keeps coming lose or i break them. Went to a grade 8 bolt lock tight red lock washers and no luck even a nylon nut that lasted three days. Check everything looks good. Thanks Jeff
Old Jun 8, 2014 | 01:27 PM
familytime's Avatar
JK Forum Regional Rep
Need more info,any other bolts coming loose
Old Jun 8, 2014 | 02:22 PM
gunbo75's Avatar
Nope just that small bolt. track bar is OK
Old Jun 8, 2014 | 08:33 PM
gunbo75's Avatar
Hey Teraflex any idea I drove it 2 days and it came loose again so new bolt new lock washer and red loctite try again about ready to lose my mind.
Old Jun 9, 2014 | 06:48 AM
fsr402's Avatar
what poundage are you torquing the bolts to?
Old Jun 21, 2014 | 07:22 PM
gunbo75's Avatar
Damn this little bolt. I'm about ready to freakin weld this bracket.
Old Jun 23, 2014 | 11:50 AM
fsr402's Avatar
Do you have the crush spacer in there?
Old Jun 23, 2014 | 12:34 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Do you have the frame side or axle side bracket?
Old Jun 23, 2014 | 07:17 PM
gunbo75's Avatar
Hey teraflex here is a picture .I am not sure what side you're talking about..
Thank you teraflex
Old Jun 23, 2014 | 07:21 PM
Ncb's Avatar
Ncb
I'd dump that bracket and get the bracket that mounts to the axle for two reasons. That mount puts extra stress on the frame bracket and also lowers the roll center. Not a good design.
