Yukon 5:13 setup issues 2013
Old Jun 9, 2014 | 08:13 AM
fitchottie's Avatar
Default Yukon 5:13 setup issues 2013
Called over to ECS, and they stated there are a lot of issues right now with the Yukon gear 5:13 and setup. So much so they are no longer recommending them, instead they are pushing DANA Gears. Anyone having any issues?
Old Jun 10, 2014 | 02:26 AM
OH9JK's Avatar
JK-Forum Ambassador
If Chase is recommending to stay away from a certain brand, then I would follow his advice. That shop does gears and axles all day, every day.
Can't go wrong with DANA parts although sometimes you are limited in your ratio selection.
Old Jun 10, 2014 | 02:41 AM
jrod250's Avatar
From what I've read and how I understand, all or at least most gears are all made by the same manufacturer, just with a different name on them when they Leave. If that is in fact true, then it's not just Yukon that has problems.
