No power with the top/doors off
Old Jun 9, 2014 | 07:30 PM
mikepov's Avatar
Default No power with the top/doors off
When cruising on the highway ill be sittin in 5th gear and the slightest incline i will lose momentum even tho I'm flooring it sometimes i hav to shift all the way down to 3rd to pick up and maintain speed i figured since its terribly un-aerodynamic with the doors and top off thats the problem and im sure running 35s with stock gearing is also contributing.... i just wanna see if this is normal and if any has any suggestions to help out?
Old Jun 9, 2014 | 07:37 PM
mikepov's Avatar
I guess regearing is a good solution i been wanting to do this any way but can i just upgrade the rear dif or do i hav to do front and rear?
46chevytruck's Avatar
Normal. Mines an auto and it was very common until I installed 5.13's and then it was less frequent (only larger hills and long more gradual inclines ). Then I supercharged it and no longer have that problem. (Expensive "fix").
You need to do both front and rear gears or you will have a catastrophic failure!
Old Jun 9, 2014 | 07:40 PM
ronjenx's Avatar
You have to re-gear both ends. If you do only the rear you will not be able to use the 4wd option.
Old Jun 9, 2014 | 07:42 PM
mikepov's Avatar
Ok thanx man once again is it ok just to regear in the rear or do u have to do the front and rear at the same time and also is there anything else besides the ring and the pinion? Do i need a whole new dif or driveshaft or anything ...can u resize the gears in the stock difs?
Old Jun 9, 2014 | 07:43 PM
mikepov's Avatar
Woops ok thanx guys by the time i wrote that last reply u guys answered my question
Old Jun 9, 2014 | 08:00 PM
meep97's Avatar
You can regear the rear and then later on do the front. You will not be able to use 4wd if you just regear one of your axles. Both axles have to have the same gear ratio to use 4wd.
You will need a ring and pinion and depending on the millage of your jeep, you will need either a master overhaul kit or an install kit.
You don't need a whole new differential or driveshaft.
You can regear a Dana 30/44 combo up to 5.13 gears. And regear a Dana 44/44 combo up to 5.38 gears.
