2014 rear main seal leak!!!!
Old Jun 10, 2014 | 10:02 AM
WINGIT's Avatar
Default 2014 rear main seal leak!!!!
Only has 7,000 miles. Anyone else have their rear main seal leak? It's at the dealer now. They said 3 days to fix. A good ole boy could probably get it done in an afternoon
Old Jun 10, 2014 | 10:22 AM
5150cliff's Avatar
Not a big deal really. Could have been a damaged seal to begin with or installed wrong. I'm sure once it's fixed, you'll be fine.
Old Jun 10, 2014 | 12:33 PM
goaterguy's Avatar
yes, but a good ole boy will charge you to do so. Relax and let the dealer handle it. It'll be good as new when you get it back.
Old Jun 11, 2014 | 08:31 AM
WINGIT's Avatar
It wasn't that good when it was new but oh well! LOL Should be getting it back today which is good cause I am having withdrawls!!!
Old Jun 11, 2014 | 10:11 AM
goaterguy's Avatar
That's why I said "as good" LOL. I made an appointment for mine because the tailgate rattling is driving me nuts! Jeeps are like a mistress that constantly requires attention to make you happy...
Old Jun 11, 2014 | 03:44 PM
tac's Avatar
tac
Default It's probally the oil cooler under the intake manifold
If you've let a novice change your oil filter he probally cracked your plastic filter housing by torqueing over 18 inch pound not foot pounds destroying or cracking the oil cooler.
Old Oct 19, 2014 | 09:13 PM
jwoog's Avatar
I have a 2012 JKUR with 23,000 miles on it. Just found engine oil leaking from between motor and transmission.
Old Jan 15, 2015 | 07:47 AM
rabbitdave's Avatar
Default Will be taking into dealer after wheeling
I have a '13 that is leaking oil between the engine and manual transmission. Looks like the rear main seal for some reason. Will be taking into the dealer for warranty work if it continues. Only have 18K and already have a leak. Would putting larger tires or extreme cold allow a leak? I am hoping it is just the seal contracting in the sub zero weather and is not big deal.
Old Jan 15, 2015 | 07:55 AM
Captfranny's Avatar
Same story with a 12'. Luckily warranty covered it. 2 full days at dealer.
Old Jan 15, 2015 | 04:40 PM
boon4376's Avatar
Mine leaked after around 18k miles in my 2013 with 6 speed MT. The gasket they use from the factory is terrible. Had it fixed and no problems since.. however, now my drivers front axle seal is leaking. The diffs leak if they take any sort of impact because the gasket is so brittle.
.. My throw out bearing is also garbage. At this point I'm glad I opted for the 100k mile warranty .. cause these things sure don't get more reliable as they age.
