Rear Upper Control Arm forward bolt...easy peasy.
Old Jun 12, 2014 | 08:30 AM
14Sport's Avatar
Default Rear Upper Control Arm forward bolt...easy peasy.
So I decided to adjust my rear pinion angle as it was a 1.75* off. I struggled for two hours getting the passenger rear upper control arm front bolt to catch (tougher with the lowers already in place). So after a couple of quick attempts on the driver's side, I moved the control arm out of the way so I could get an idea of how for in the nut tab has to go to be aligned with the hole. I was going to get it aligned and mark the tab with a sharpie (probably should have done that before I removed them). So anyway, I found that if you set the nut right against the inside of the frame and slide up from the bottom, it gets wedged on something about 1/8" short of the bolt hole. So I took a dead blow hammer and tapped it into place, using the bolt without the control arm to make sure it was perfect. It held in place. Then I removed the bolt and attached the control arm. Less than 5 minutes total.
Enjoy!
Old Jun 12, 2014 | 02:50 PM
Christian13's Avatar
What is the pinion angle supposed to be? I have mine set so that there is no angle on the tailshaft joint
Sent from my C6603 using Tapatalk
Old Jun 12, 2014 | 02:56 PM
14Sport's Avatar
With an aftermarket ds, it should be inline with the ds. If you're running the stock ds, it should be the same angle as the transfer case.
Old Jun 12, 2014 | 06:32 PM
How does this look? It is lifted about 4 inches
Old Jun 12, 2014 | 07:18 PM
Invest2m4's Avatar
Originally Posted by Ultra4
How does this look? It is lifted about 4 inches Sent from my C6603 using Tapatalk
Bad. Stock DS uses a CV (rzeppa joint). It's designed to run at an angle, not straight on like an after market shaft. The angle of the pinion should match the angle of the t-case output. So, two parallel lines.
Old Jun 12, 2014 | 07:30 PM
meep97's Avatar
That would be closer to the correct angle for an aftermarket DS.
Old Jun 12, 2014 | 07:43 PM
So I need to rotate the axle forward?
I really appreciate the help
Old Jun 13, 2014 | 01:48 AM
14Sport's Avatar
You do. Use a cheap angle finder from Harbor Freight or Home Depot. They're less than 10 bucks. At least you now know an easy way to get the upper control arm bolt in.
These pics were before I fixed it yesterday.Click image for larger version
Name:	Rear Pinion 001 (Small).jpg
ID:	559339Click image for larger version
Name:	Rear Pinion 002 (Small).jpg
ID:	559340Click image for larger version
Name:	Rear Pinion 003 (Small).jpg
ID:	559341Click image for larger version
Name:	Rear Pinion 004 (Small).jpg
