How do i add an oil pressure guage to 2012 JK wrangler?
Old Jun 13, 2014 | 07:06 AM
Malto24's Avatar
Default How do i add an oil pressure guage to 2012 JK wrangler?
So I am looking for some help with adding a oil pressure gauge to my 2012 Jeep Wrangler Sahara 4dr.
Does anybody know how to put a oil pressure gauge on a 2012 jeep 3.6L V6? I have found all the gauges and a pillar pod to mount them on but I am looking for someone that has done this. Is there another port other than where the oil sender is at on the back side of the engine?
Old Jun 13, 2014 | 07:19 AM
mistasparkl's Avatar
You can just run an Aeroforce gauge which monitors a whole bunch of parameters including oil pressure, as the PCM is already monitoring this. Its plug and play into your obd2 port. This is what I am running to monitor trans temps, oil pressure, coolant temps, etc.
Old Jun 13, 2014 | 01:07 PM
Malto24's Avatar
Thanks for the reply. that is what i am finding out probably less expensive in the long run and will get more out of that type of read out.
Old Jun 13, 2014 | 04:10 PM
Mark Doiron's Avatar
If you have an Android tablet or phone, you might check around if anyone is using Torque Pro to monitor oil pressure. Ask how they did it. I use Torque Pro on my '07, but oil pressure was not monitored back then (just a good-bad switch). I can read out lots of other things, though.
