Teraflex Tire Carrier Question
Old Jun 13, 2014 | 08:12 AM
Bear_13's Avatar
Default Teraflex Tire Carrier Question
I just wanted to see if anybody knows if you can move the studs from one position to the next. I currently have 33"s and would like to have 35"s in the future. And how did you get the studs in? Thank you.
Old Jun 13, 2014 | 08:15 AM
TxJeepers's Avatar
Yes, I have moved them. Did so after calling Teraflex. No big deal.
Old Jun 13, 2014 | 08:17 AM
Bear_13's Avatar
Did the rattle at all after moving them? How did you get the studs out of their original position to move them to the next?
Old Jun 13, 2014 | 08:29 AM
TxJeepers's Avatar
No, no rattle. No problems. Was prepared to have to order new studs from TF but did not have to. I used a BFH to pound them out.
Old Jun 13, 2014 | 09:10 AM
DallasJKU's Avatar
This is good to know when I go to 37's even though the 37's will fit with my MetalCloak bumper where my 315's are mounted now.
Old Jun 13, 2014 | 09:15 AM
Bear_13's Avatar
I'm having a hard time getting them in. How did you insert the studs?
Old Jun 13, 2014 | 10:30 AM
XTJake's Avatar
Former Vendor
You can probably install them the same way you'd install wheel studs in the axle. Put the stud through the plate, put a bunch of washers on the stud, then tighten a nut on the stud so it pulls the shoulder into the plate. Good Luck!
-Ryan
Old Jun 13, 2014 | 11:34 AM
mrlobaloba's Avatar
This video will show you.
https://www.youtube.com/watch?v=GxmPoaqdtbc
Old Jun 13, 2014 | 11:40 AM
nthinuf's Avatar
I was lazy, just took that piece down to my gear guy and had him press them in...
Old Jun 13, 2014 | 12:28 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Well that will work also! Thanks for buying TeraFlex!
