evo rear corner rock skins
Old Jun 15, 2014 | 04:33 PM
texjeeper's Avatar
Default evo rear corner rock skins
Hello everyone just had a quick question hopefully someone can answer it for me. What size drill bit should i use for the nutserts that come with the rock corners? I received my rock skins but no instructions and i can't seem to find this info any where and luck hearing from off road evolution.
Old Jun 15, 2014 | 06:19 PM
mark_c's Avatar
I would measure the nutsert and drop down a size drill bit. You want them to fit slightly snug. And if it doesn't fit you can make the hole a little larger.
Old Jun 15, 2014 | 07:45 PM
loserhead4236's Avatar
While the skins are on the jeep, drill using a 5/16. Remove the skins, and open up the holes using either a 25/64 or a 3/8. I just got done with this install a few weeks ago and can help out if you need more info.
Old Jun 16, 2014 | 02:27 AM
texjeeper's Avatar
Thx so much for the info guys I can finally get started.
Old Sep 23, 2014 | 12:30 PM
Mine should be here thursday or friday, i will be tackling the install over the weekend. a friend is bringing me a industrial riv-nut install tool from his work, so that should make it a lil easier. my question is, how much work do you have to do to the skins to make them fit as close as possible to the body?
Old Sep 23, 2014 | 04:28 PM
Get some ratchet straps and vice grip clamps to help with the install. you definatly need to work them to hug the side of the jeep
Old Sep 24, 2014 | 01:23 PM
my corner armor showed up today, seems pretty nice.....but no hardware was in the box, so i emailed them and they are sending it out today. guess ill have to wait till next weekend to put them on
Old Sep 24, 2014 | 01:31 PM
AngryRedBird's Avatar
Write up is right here: https://www.jk-forum.com/forums/jk-s...nstall-178354/
Old Sep 26, 2014 | 04:25 PM
for evo mfg's customer service, i emailed them about my missing hardware, within 20min i got a reply that it will be sent out, and it showed up the next day
