Stock P255/75R17 wheels or 265 70 17
Old Jun 15, 2014 | 10:07 PM
forestJK's Avatar
Default Stock P255/75R17 wheels or 265 70 17
Can someone please tell me, what tire size is taller, Stock jeep JK P255/75R17 wheels or 265/70/17. If you have pictures of comparison, please post up.
Old Jun 15, 2014 | 10:11 PM
Smitty12JKU's Avatar
I believe the 255 is by a small amount. It will also depend on which tire. The best way to know is to look up the specifications on the manufacturers website. Every tire I have ever considered was easy to look up and the over all diameter.
Old Jun 15, 2014 | 10:24 PM
forestJK's Avatar
Duratracs, lets use them as example 265 70 17. I want to run these with a leveling kit after my 285's wear down, or maybe i can sell them. The 265 duratrac overall diameter says 31.7, the stock jks are...
Old Jun 15, 2014 | 11:31 PM
Stock 255/75R17 = 32.1"
Old Jun 16, 2014 | 06:47 AM
kmrtnsn's Avatar
A great tool.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old Jun 16, 2014 | 05:21 PM
lowendrider's Avatar
The 265 70 17s are slightly shorter and slightly wider. I've got the 265 70 17s...
ID:	560145   Click image for larger version
ID:	560146   Click image for larger version
Old Jun 17, 2014 | 01:43 PM
forestJK's Avatar
Really cool, hey it actually looks like the 265 are taller then stock in your photo...right
EDIT" Those stock wheels you have are actually the 225/75R16
Old Jun 17, 2014 | 03:20 PM
onlyone's Avatar
Here are 265/70's on mine.
The last one was while I was changing my tires back and installing lift. I had 265's on the rear and the factory 255/75's on the front.
ID:	560308   Click image for larger version
ID:	560309   Click image for larger version
Old Jun 17, 2014 | 05:40 PM
I believe both these photos are before I swapped rear springs from 55s to 59s..gained 3/4 to 1 inch...sits about perfectly level with the 17 front springs and 1" spacer (had 14s) even with the winch. Hope this helps
ID:	560363   Click image for larger version
