Synergy tie rod- hanging lower thank stock?
Old Jun 17, 2014 | 08:04 AM
mattyk's Avatar
Veteran: Navy
Default Synergy tie rod- hanging lower thank stock?
Recently installed the synergy tie rod. Is it me or dues this thing hang lower than stock? It's got quite a bit if pivot movement but it's buttoned up tight on the bolts and castle nuts.
Anyone else have the same issue?
Old Jun 17, 2014 | 08:41 AM
Krawlersaur's Avatar
I angled mine up before I tightened the jam nuts. Hasn't fell down since. Try that?
Old Jun 17, 2014 | 08:44 AM
Monte417's Avatar
Can you post some pics of the orientation of your joints im having the same issue
Old Jun 17, 2014 | 08:52 AM
The joints are slightly angled. Nothing I would call dramatic.
Old Jun 17, 2014 | 09:08 AM
mattyk's Avatar
Veteran: Navy
Attachment 560256
Attachment 560255
you have your tightening nut (the on on passenger side to clamp the bar after the jam nuts are set) facing down. i have mine facing back to avoid jacking it up on a rock.
Old Jun 17, 2014 | 09:21 AM
Monte417's Avatar
Attachment 560256
Attachment 560255
Wow you certainly do have that bar angled up high. Thanks
Old Jun 17, 2014 | 09:35 AM
Its a compromise. By turning the angle down, the bolt will slide to the back, but make the TR lower. However, I feel that the bolt is close enough to the wheel, that I will be going over it, rather than dragging it.
Old Jun 17, 2014 | 04:28 PM
jeepwave's Avatar
Here's some close ups of mine. Doesn't seem to sit that low either
Old Jun 18, 2014 | 10:00 AM
Smashboogie 4x4's Avatar
Former Vendor
Looks like the OP has that tie rod pointed down. You want the bends pointing straight forward. The bends are in the tie rod to prevent the tie rod from contacting the diff at full lock.
Old Jun 18, 2014 | 10:09 AM
mattyk's Avatar
Veteran: Navy
actually its level. thats from the angle of the photo. ill get some better pics this afternoon. im really have tempted to angle this thing up slightly though. its almost level with the bottom of the diff and that cant be right
