EVO Rubicon Manual Sawybar disconnect question
Today I just found out my Rubicon Electronic sway bar disconnect was shot so I decided to go with The EVO manual disconnect Knob solution. My question is what do you do with the wiring harness that's left over when you do away with the motor? If moisture is what screwed it up and it's sending bogus messages to the computer then is there a need to seal it up somehow or will using the Procal to disable the swaybar light over ride the messages from the harness to the computer?
Sent from my iPad using JK-Forum
A heavy duty plastic bag and wire tie work great. Just the corner of the bag to avoid a bunch of extra material.
With a Procal (or other capable programmer) you'll need to disable the system to get rid of the light.
