Secure storage for 2 door with no backseat
Old Jun 22, 2014 | 07:12 PM
ShutterBug's Avatar
Default Secure storage for 2 door with no backseat
I have a 2014 JK 2 door. I don't run with a back seat and I am looking for ways to secure stuff in the back.
I looked at some of the Tuffy products, but they seem to be easily circumvented. I have power door locks, so all a potential thief would have to do is unzip a window and click the unlock button and it opens the tailgate.
What do others do to secure surf in the back?
Old Jun 22, 2014 | 07:15 PM
Ncb's Avatar
Ncb
The power door lock switches are disabled after locking the doors with the key FOB. Tuffy stuff would be totally pointless if one could simply reach in and unlock the tailgate.
Old Jun 22, 2014 | 08:27 PM
D_engel's Avatar
what are you looking to store so I know how much room you will need?
Old Jun 22, 2014 | 09:48 PM
jeepmojo's Avatar
Default i just got a sportsmans trunk for like 45 bucks
@ cabela a while back and put it in there ,drilled a couple of holes inside and ran a cable through with lock on inside of box attached to the seat brackets on floor Click image for larger version
ID:	561364 but it has a place for a padlock already , I hardly ever lock it so its easy to go in and out of lol
Any metal or hd plastic box would hold stuff and be secure tractor supply co. has trunks too .
Old Jun 22, 2014 | 10:11 PM
Blue Fish's Avatar
In my 2012 Wrangler Rubicon with the tops off I was always worrying about leaving items in the back while on excursions so this is what I came up with.
The Rubbermaid 48 gallon action packer cargo box is reasonable price $78 (Walmart), high capacity, weather proof, light weight, durable, secure, color matching and fits perfectly in the place of the rear seat it leaves room behind front seats for reclining and additional space and allows access to the factory rear under-floor compartment and jack access.
I drilled holes in the bottom and using U-bolts attached the container to the metal rear hold down loops for the rear seat, looped the U-bolts thru the seat hold downs up thru the drilled holes in the bottom of the container and secured with metal plate, bolts and rubber caps over the exposed threads to protect items placed in storage container.
ID:	561365Click image for larger version
ID:	561366Click image for larger version
ID:	561367Click image for larger version
ID:	561368Click image for larger version
Old Jun 23, 2014 | 07:41 AM
ShutterBug's Avatar
Boy, do I feel dumb. I had to go test this and you are right. For some reason, I could have sworn I was able to do this before.
Old Jun 23, 2014 | 07:42 AM
ShutterBug's Avatar
Recovery gear and trail gear that I rarely remove from the Jeep: Recovery straps, shackles, compressor, rain gear, etc.
Old Jun 23, 2014 | 10:20 AM
DJ1's Avatar
DJ1
Former Member
Attachment 561365Attachment 561366Attachment 561367Attachment 561368Attachment 561369
Thanks for posting this up. This gives me an idea on how I can use some spare Pelican cases I have sitting in the garage.
Old Jun 23, 2014 | 02:58 PM
theblksheep's Avatar
I came across this in my search for the same thing that you are looking for, I don't have it but figured it might help. Jeep Backbone Home Page
Old Jun 23, 2014 | 03:46 PM
jeepmojo's Avatar
Default i like this way of attaching to floor
good tip never thought of u clamp I used a cable I might use this method now it cant move at all this way
