Truck-Lite high beams not working.
Hi all, I'm curious to know if anyone who is running truck-lites on there wrangler has had a similar issue and may have some insight. I put the Truck-Lite 7" on the wrangler about 5 months ago and have not had any problems except the common flickering. over the weekend the drivers side light went out completely. I did some digging and found the cable connection had come loose and the actual connections were slightly corroded. I cleaned them out and reconnected the wires and everything was working well , till last night.
On my way home from work with both low beams working properly I attempted to switch the lights to High beams and they both went out. when I switched back to low beam they came back on. I went back and checked the connections and can't initially find anything wrong. I looked for a fuse and cannot identify a specific one for the headlights and haven't found any blown fuses. I am totally stumped, I spoke to Truck-Lite support and all I got from them was "the red wire must be pinched somewhere".
Hopefully someone can help thanks in advance.
I had the same thing happen to me after about 4 or 5 months. Took lights off and plugged it back in. I didn't notice any corrosion on the lead but it was a little loose. I'm curious, who did you order yours through? I'm wondering if connectors are of different quality from the different vendors. Now that I plugged them in they are working fine. Hopefully it lasts.
The connectors might be coming apart from normal driving. You can try the zip tie technique to keep the connectors tight. Cut a small notch on the "ears"on the headlight side of the connector and then put a zip tie around both connectors and both sides to form an X. My low beams would not function due to coming apart ever so slightly. After zip tying them, I've had no problems.
