OME Rear Panhard Bracket or other Rear Trackbar Brackets
I'll be getting the RC 2.5 BB light (with shock adapters). I have read that some people have issue with the rear track bar. I really don't wana spend the money on an adjustable rear track bar.
Has anyone used the OME rear panhard bracket bracket to compensate for the lift? Are people using other brackets? Do I really the bracket?
Thanks for the info
Thanks for the info
I installed the RC 2.5 kit last weekend. My front axle is perfectly centered but my rear is shifted about 3/4" to the passenger side. Yesterday I ordered the BDS rear to address this. I'll let you know how it works out once I get it installed.
bds-suspension dot com search for 124308
i drove my OME LD 2" with and without the OME bracket. You do not need it, but my rear axle is now nearly exact centered and the ride is better, because there is much less side shift while the suspension is working. Negativ: You will need bumpstops (included), because otherwise the bracket would collide with the shock ...
Do you happen to have a link or part number. The only one I found was weld on and thats not something I wana mess with.
