Really bouncy ride
Old Jul 9, 2014 | 09:12 AM
csbkdd's Avatar
Default Really bouncy ride
My axle is off-centered about 2 inches to the left while looking at the jeep. This is causing my coils to have a bow in them and also the bump stops to be touching the side of the coils. I already have an adjustable track bar on the way to re-center the axle. So my question is that is it because my coils have a bow and are not straight the reason my ride is bouncy? and I mean REALLY bouncy. Thanks!
Old Jul 9, 2014 | 09:26 AM
Tripletsi's Avatar
Your axle is two inches off and you have an adjustable track bar? Did you adjust it the wrong way?!?
Old Jul 9, 2014 | 09:33 AM
lowendrider's Avatar
The OP stated he had the adjustable tracbar on the way..
SpicedCrusher's Avatar
He has an adjustable track bar on the way.......
Old Jul 9, 2014 | 11:50 AM
Freewill's Avatar
With or without the track bar, the bouncy ride is almost for sure a bad match between the springs and shocks.
Old Jul 9, 2014 | 12:06 PM
Tripletsi's Avatar
Thanks, read over the "the way" part. My bad!
Old Jul 9, 2014 | 12:47 PM
csbkdd's Avatar
I would agree except it is only on the passenger side. Drivers side rides just fine. Maybe the drivers side shock is bad??
Old Jul 9, 2014 | 01:10 PM
Mark Doiron's Avatar
Did you mean passenger's side? Regardless, disconnect the shocks and see if they have pressure.
Also, when the lift was installed, were the trackbars and control arms all loosened while lifted, and then not tightened and torqued until full weight was on the ground?
Old Jul 9, 2014 | 01:28 PM
csbkdd's Avatar
Yes I meant passengers side is probably bad. I'll unbolt it shortly and check the pressure. And It has been lifted for awhile now, I just never got around to buying a track bar to align my axle because the ride was fine! Just in the past few days has it gotten bouncy and I was trying to figure out why. My guess is the shock though
Old Jul 9, 2014 | 02:22 PM
Freewill's Avatar
If the ride was OK at first with those shocks, and if the problem is one side only, then it could be a defective shock. A bad shock would be a mis-match with the spring for sure!
Also, the comment about tightening the assembly with the Jeep on the ground is important. When the bolts are tightened with the Jeep on jack stands it puts unwanted pre-load on the components and weird things will happen with the ride and handling.
