Will Nitto Trail Grapplers 35x12.5x17 fit on my Stock 17 Inch Rims?
Old Jul 9, 2014 | 11:37 AM
TakeABackRoad's Avatar
Default Will Nitto Trail Grapplers 35x12.5x17 fit on my Stock 17 Inch Rims?
Anyone here running Nitto Trail Grapplers 35x12.5x17 on stock 17 inch rims? I am trying to avoid buying new rims right now and was curious if these would fit without an issue. Thanks in advance.
Old Jul 9, 2014 | 11:56 AM
v8zracer260z's Avatar
Veteran: Marine Corp
You will generally a 8.5" to 9.5"wide rim with 4.0 BS or less. I have a friend with 35x12.5R17 mud grapplers on stock rims with spacers though.
Old Jul 9, 2014 | 12:54 PM
5150cliff's Avatar
Will they fit on your rims? Yes. Will they rub somewhere? Perhaps. Will you need spacers to make them work? Probably. But they will fit your rims.
Old Jul 9, 2014 | 01:27 PM
I have spacers that I can use. I know technically they would fit. I was just seeing if anyone ran into any issues. I appreciate the input
Old Jul 9, 2014 | 03:09 PM
jadmt's Avatar
JK-Forum Ambassador
my buddy has the grapplers and they are wide as all get out. I think they would be too wide for stock rims. you might be able to get them mounted but would not be the best choice.
Old Jul 9, 2014 | 03:14 PM
Twinkydog's Avatar
Running 35x12.5x17 Toyo MT's with spacers on stock rims and I have not had any issues.
Old Jul 9, 2014 | 04:23 PM
gburkett's Avatar
local guy here has 35x13.5x17 on stock wheels.
Old Jul 9, 2014 | 04:40 PM
wittys-jk's Avatar
V8zracer260z friend is also a guy I wheel with on 35 mud grapplers on stock wheels with spacers. Wheels fine no rubbing and they look good on his rig
Old Jul 9, 2014 | 05:12 PM
mattnunes's Avatar
35x12.5 on stock rubicon x wheels with 1.5" spacers
ID:	564442   Click image for larger version
Old Jul 9, 2014 | 06:17 PM
5110's Avatar
I'm running the same setup, they fit on the rims, but you need wheel spacers to keep them from rubbing.
