Noises with teraflex 2.5 lift
I just had a tearaflex 2.5 lift installed with a billstin shocks. I am hearing a rattle noise whenever i go over a bump and a clunking noise in the front when I brake. these may be normal but i have no idea. Anybody have any ideas what these could be? my apologies for my incompetence.
Thanks
Thanks
I also have the Teraflex 2.5" lift (installed on 2012 4-door). Have had it installed for about 2 years. I have never encountered any of the noises you describe... Not much help other than it is not normal.
I installed the TF 2.5in coil lift with Bilsteins 5100 and Synergy arm myself around a week ago.
Drove around town for two days and went on two trail rides overland style. However, drove up to 80mph on highways and tried to push the Jeep on the trails (drove fast, climbed some stuff, etc.) to have a feeling for its (new) behavior.
No (new) noises.
However, I followed the TF's video, install instructions and several online advice to the letter and spent close to 10 hours (seven if discounting the two front schocks' top studs) doing it alone.
I would flex the suspension to the limit on both sides, front and back, and check if anything is looking "funny" under the Jeep.
Notice that several bolts must be tightened with the Jeep resting on the ground, not lifted.
No (new) noises.
Swaybar bolts tight ? Springs properly seated ? Shock bolts tight ? 3 very common issues I see all the time.
As mentioned .. Did you loosen all CA/TB bolts and torque at ride height (tires on and on the ground)?
2007 Rubicon /2 door/6 speed
Something is loose, bound or a bushing preloaded. Buy a grade 8 kit, then replace the bolts while doing the famed DW checklist in the sticky. That should fix it or atleast help you understand where the noise may be coming from. Also its a necessary upgrade anyways.
The top shock bolts in the fenders are not easy to get to unless you have the right tools. Mine were not fully tight when I first put it on and there was a very slight rattle that I could here when hitting bumps. It sounds like a washer rattling around on the bolt, so it wasn't a loud rattle.
If you had a shop professionally install the lift, I would take it back to them and tell them to look everything over!
You would think right? Same issue i ran into with 4wheelparts here locally. After bringing it back 4 times its still not done right. But yes buy a grade 8 hardware kit. My trackbar has some play when i wheel ( thats only when i hear it ). The grade 8 kits are just a tad bigger than the stock bolts which help with that kind of stuff.
