Alignment spec sheet questions
Old Jul 13, 2014 | 12:33 PM
mhockey9090's Avatar
Vet Army
Default Alignment spec sheet questions
Heres the sheet from firestone. If you cant read i will put the numbers here in the forum for you guys. Any input would be great guys.
Current Front:
-Camber-
Left Right
-0.6 -0.6
-Caster-
Left Right
4.0 3.9
-Toe-
Left Right
.10 .10
Current Rear:
-Camber-
Left Right
-0.4 -0.3
-Toe-
Left Right
0.27 -0.02
-Total Toe-
0.25
-Thrust Angle-
0.14
Old Jul 13, 2014 | 12:52 PM
D_engel's Avatar
a little more caster wouldnt be bad but everything else seems to be okay. Any uneven tire wear or handling issues you are concerned with?
Old Jul 13, 2014 | 01:00 PM
Vet Army
No just want to make sure i don't need to make any adjustments. I have the RK 2.5 X factor so i have all 8 adjustable control arms. The caster i would fix by adjusting the uppers correct?
Old Jul 13, 2014 | 01:30 PM
nthinuf's Avatar
Yes, shortening the uppers would lower the pinion and raise the caster. And lengthening the lowers would do the same thing. But, assuming the axle is centered front/back in the wheel well, shorten the uppers.
Old Jul 13, 2014 | 01:36 PM
Vet Army
Would it be safe to take off the upper when the vehicle is sitting on its own weight? I know about getting them back on with using a jack to help with aligning them back together.
