Thinking about the JCR Offroad Vanguard Front Bumper, but I have concerns
I have a 2013 Sahara, and I am looking at getting the JCR Offroad Vanguard full width front bumper. It's gonna cost a decent amount after powder coating it and having to order the skid plate separately and get that powder coated as well.
I've heard that for 2013 models, the vacuum pump has to be moved in order to install the bumper. Has anyone installed a JCR front and found a way around this? On JCR's website, they have a YouTube video and they advise cutting two pieces that are used to secure the vacuum in order to use the mounting bracket that allows you to lay the vacuum pump horizontally to proceed with installing the bumper. Here is the link[fast forward to 1:42 to see the part where they are working with the vacuum pump]: https://www.youtube.com/watch?v=Exx3e1ZuPm0 I like the bumper a lot, but having to invest what will be over $1,000 and still have to make slight modifications by making the cuts in my vehicle, I've been a little hesitant.
Also, I live in Virginia where we have to have front licenses plates. Is there an easy way to install that?
Thanks for the help, guys!
I installed the JCR stubby with recessed winch. Cut the vac bracket, used the new bracket, no issues. For the front plate, I drilled and tapped the bumper and bolted the plate on.
Absolutely no one will know that you have "Cut" your vehicle... its all hidden behind any bumper.
For license plates, I recommend getting the AEV license plate bracket that mounts between the fairlead and the bumper. You can run it high or low, has quick releases for the license plate and looks very professional. (its the only AEV product I'd recommend).
I have the JCR Stubby with factory fogs. No modifications to the JK at all. I believe that any bumper with a recessed winch (mine is not) requires moving the vacuum pump.
However, JCR provides the bracket and instructions to move it properly.
Call the guys at JCR. I have met them on a couple of occasions and I couldn't be more impressed with the product or the people. Just received my mid width rear bumper. Hoping to get it installed tomorrow or Friday.
Any bumper with a sunk down winch will require relocating the vacuum pump on 2012-2014 JK's. It's one of the trade offs for the design.
It's not a big deal and easy to do. We've even had customers that have told us that they only had to cut the threaded stud off the top of the factory bracket for the bumper to clear.
Give us a call or shoot us an email if you have any questions. We don't spend a lot of time browsing forums. Info@jcroffroad.com or 269-353-1184.
~Brian
~Brian
TIA!
JT
I think you'll find it very hard to find a recessed winch, stubby bumper, with factory fogs. There just isn't that much room in there for all of that and make the bumper string enough to handle a winch pull.
The JCR line up has always been a favorite of mine. I have the Dagger, which has factory fogs, but not a recessed winch. I believe the have another that has the recessed winch, but not the factory fogs.
If you found one that had both options, I would look closely at it to see just how strong of a bumper it is. You might lose something that you CAN'T see and it might to be what you want.
I think you'll find it very hard to find a recessed winch, stubby bumper, with factory fogs. There just isn't that much room in there for all of that and make the bumper string enough to handle a winch pull. The JCR line up has always been a favorite of mine. I have the Dagger, which has factory fogs, but not a recessed winch. I believe the have another that has the recessed winch, but not the factory fogs. If you found one that had both options, I would look closely at it to see just how strong of a bumper it is. You might lose something that you CAN'T see and it might to be what you want.
