Assistance to Identify Lift
Old Jul 23, 2014 | 06:59 AM
Vladimer's Avatar
Default Assistance to Identify Lift
ID:	567058Click image for larger version
ID:	567059Click image for larger version
ID:	567060Click image for larger version
ID:	567061Click image for larger version
Here is what I am starting off with on the 4 door. I assume it is about 2-2.5" kit as the rear brake line is just a drop bracket. I believe I've seen the logo before that is stamped into the plastic shock cover but I can't put my finger on the name.
Doesn't drive bad, steering seems tighter then on my 2 door. But I get some crazy wobbling between 30-45mph. Nothing on the highway.
Any ideas?
Old Jul 23, 2014 | 07:00 AM
Vladimer's Avatar
ID:	567063Click image for larger version
Last two pictures.
Should I trim the pinch seam/rail anymore? It looks like he DIY trimmed the rear fenders as well.
Old Jul 23, 2014 | 08:51 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Looks like you have a Zone lift from the logo on the shocks. Try looking on their website to ID which lift version you have.
Old Jul 23, 2014 | 04:07 PM
glock-n-roll's Avatar
Definitely Zone shocks. You have more than 2.5" of lift though. My JKR (yes, 2 door) measured 36" at the front fender flare bottom edge before my lift sitting on stock 255-70-17's. After my RK 2.5 lift I measured 40" on stock tires (I know, 4" of lift on a 2.5 kit, lol). Throw in your bigger tires and I will venture a guess at a Zone 4" lift for sure.
Old Jul 23, 2014 | 04:25 PM
kjeeper10's Avatar
Vet Army
Balance the tires first.
The Have somebody turn the Steering wheel 9-3 looking for any play in the front track bar, tie rod ends, steering box. Then raise each tire and inspect the ball joints/hub bearings. Check torque on all suspension bolts.
2007 Rubicon /2 door/6 speed
