35's on Stock Rubicon Wheels
Old Mar 1, 2008 | 08:04 PM
txaggie's Avatar
Default 35's on Stock Rubicon Wheels
Does anyone have any pics of their rig with stock rubicon wheels on 35" tires?
Old Mar 2, 2008 | 02:01 PM
AZJeeper's Avatar
Community Favorite
Can you safely mount a tire that big on wheels 7.5" wide? I know BF Goodrich doesn't recommend it. Do other tire manufactures allow that narrow of rim for their tires?
Old Mar 2, 2008 | 05:55 PM
txaggie's Avatar
Thanks for the advice I should probably look at some Walker Even wheels.
Old Mar 2, 2008 | 06:12 PM
AZJeeper's Avatar
Community Favorite
Originally Posted by SONIC
people do it alot, as long as you dotn go over 35 12.5 you shoudl be fine....you WILL need 1.25 or 1.5 spacers
People doing it a lot and being safe are two different things. I suppose if you are going with a narrow tire it's OK, but I can't find a single tire manufacturer recommends a 7.5" wheel with anything much over 33" and 10.5" wide. If anyone knows of a tire that really fits (the manufacturer says it's OK) please let us know! I'd like to see the specs!
Old Mar 2, 2008 | 07:04 PM
07crawler's Avatar
ditto...I would also like to see that
Old Mar 2, 2008 | 07:05 PM
Big D2's Avatar
Valid points. I'm curios as to how the tire behaves when aired down too.
Old Mar 3, 2008 | 06:17 AM
jkkat's Avatar
Super Swamper SSR's come in 35x 10.50 x17
Old Mar 3, 2008 | 06:49 AM
Renegade's Avatar
Here's mine on 315/70-17's:
And here it is on 37x12.50-17's:
They don't wear as evenly on a narrow rim (more wear on the center of the tread), but it can be done without any major problems. Usually people just run a little lower air pressure (@ 28 psi) to get a "flatter" footprint. Lower air pressures causes a slight loss of fuel mileage and a bit more tire roll when cornering. Good luck with your decision.
Old Mar 3, 2008 | 07:16 AM
no issues
Old Mar 3, 2008 | 07:25 AM
retep's Avatar
I had 35" cooper sst's on stack rubi wheels with 1" spacers
and the only issue was with the drivers side brake line. It did rub
in a rut and off canter almost rubbed the line off. The line
runs on the wheel side of the frame there. Peter
