AEV 2" spacer lift kit
Old Aug 1, 2014 | 02:28 PM
Shoupadupe's Avatar
Default AEV 2" spacer lift kit
Found one dirt cheap, but don't know the quality and if a spacer lift is worth it. I plan on a real suspension lift down the road, but budget says not for quite a while. Any opinions? Should I pull the trigger? Anything to worry about with just the puck spacers? The kit includes the 2" spacers, bumpstop extensions, swaybar endlink extension brackets and front and read shock extension brackets.
Old Aug 1, 2014 | 02:49 PM
jadmt's Avatar
JK-Forum Ambassador
I had one until I with the RK 1.5" triple rate coils and it works great gives you 2" up front and about 1.25" in the back. I just sold mine minus the bumps stops for $75
Old Aug 1, 2014 | 03:06 PM
Shoupadupe's Avatar
The one I'm looking at.... The guy said 10 bucks plus shipping. He said everything's like new a few blemishes on the hardware. So I think I'll pull the trigger then thanks!
