Can I run 15" wheels on 08' Sahara ?
Old Aug 1, 2014 | 09:19 PM
mredjeep's Avatar
Default Can I run 15" wheels on 08' Sahara ?
Is anyone running 15" wheels with 35 inch Tires? Will they Fit? I have OEM 18" wheels.
Will they Rub ??
Old Aug 1, 2014 | 09:23 PM
afpilot82's Avatar
JK-Forum Ambassador
There are many threads about 15" wheels, Discount Tire has a good one that lists a lot of wheels that fit. Alloys generally fit fine, some steelies rub. I run alloys with no issues.
Do you have a lift? If not, 35s will definitely rub and you will need to trim. Again, many threads on this if you search a little.
Old Aug 1, 2014 | 09:31 PM
nthinuf's Avatar
Look for a lower backspace to get the rims out far enough to clear the brakes. A 4" bs can be hit or miss, so a 3.75" or lower is what you want to go with.
Old Aug 2, 2014 | 03:33 AM
immortalmetal's Avatar
I had procomp 15" steel wheels, they had 3.75" backspacing and they rubbed on the face of the caliper. Was not happy
Old Aug 2, 2014 | 04:57 AM
notnalc68's Avatar
Check out Discount Tire's thread
https://www.jk-forum.com/forums/spon...wheels-120933/
Old Aug 2, 2014 | 07:42 AM
mredjeep's Avatar
So they do have a 15" that Does not rub the Calipers... What wheel make is that..and again the spacing.
It seems like some hit and some don't...Not sure I get that.
Thanks...Keep your suggestions coming..
Old Aug 2, 2014 | 07:49 AM
notnalc68's Avatar
Discount tire has a lot of them. There is a discount for forum members. Check out that thread & message them
Old Aug 2, 2014 | 09:42 AM
Buddylove's Avatar
This is my 07 jeep wrangler Sarah I have 4 inches of lift with cut finders and I get no rub
The Black Jeep of The Family
Old Aug 2, 2014 | 09:43 AM
Buddylove's Avatar
Oh yea 35x12.50x15 from discount tires with goodyear wrangler mtr-k
Old Aug 2, 2014 | 09:44 AM
notnalc68's Avatar
Originally Posted by Buddylove
This is my 07 jeep wrangler Sarah I have 4 inches of lift with cut finders and I get no rub The Black Jeep of The Family
Level 8 wheels?
