Nitto Trail Grapplers tire pressure?
I have these in 35x12.5 17. Discount tire inflated then to 35psi. What tire pressure for those of you that have these, use for everyday use? Max psi is 65...lol. confused? Thanks fellas!
Sent from my SAMSUNG-SM-N900A using Tapatalk
With an 8inch wide rim im around 22-24 PSI. Do the chalk test start with where your tire pressure is now and continue to let air out after each test until you get good wear from the chalk. A lot of guys will run different tire pressure due to the weight they are carrying in their Jeeps. Right now im fairly light which is why i need to air down more to have a good wear
30 psi they are E rated 10 ply tires mine had like 70 psi when they were deliverd lol even 30 seems like its more than it should be id say 30 for 35 inch tires maybe
