Shifting issue
Old Aug 3, 2014 | 04:48 PM
Tenhammer's Avatar
Default Shifting issue
12 rubi on an aev 3.5 lift with 35s. No body lift.
Every once in a while when I go from 4 lo to 2wd and then into drive my trans acts like it is only half way in gear. Revs hi barely.moves.
If I wait about 1 min or shift thru the range.of gears it goes back to normal. Now today doing tight turns going between drive and rev it would act.like it was in neutral. If I ran the shifter again it stopped being silly.
Is there an issue with the factory shifter that I don't know about?
Old Aug 4, 2014 | 07:13 AM
Jp3792's Avatar
It could be your linkage. Its a bad design its a piece of plastic. And if its broke itll act up
Old Aug 4, 2014 | 07:43 AM
jkbarnett's Avatar
I've had the same problem once in awhile. Dealer hasn't heard of this problem. I've seen it posted on several forums. 2012 Rubicon auto
