Looking for 2.5 lift with accesories
Old Aug 3, 2014 | 06:44 PM
SHOELESS's Avatar
Default Looking for 2.5 lift with accesories
Looking for opinions please. I am planning a 2.5" lift to replace my Teraflex leveling on my 2014 JKUR. My concern is sag from my Warn full width front bumper and winch, about 200 lbs. My first idea was the Teraflex 2.5 coil lift with bilsteins but heard they sag aftertime. I am also looking into AEV or RK for the triple rates springs. Any help would be appreciated.......
Old Aug 4, 2014 | 05:46 AM
20JK10's Avatar
The RK 2.5 comes in several different versions depending on what you are looking for in a kit or how much you go off-road. However, you will most likely gain around 3" of lift as RK springs give more then advertised. Their new 1.5" springs will provided 2-2.5" of lift.
Jeep Lift Kits and Suspension Systems - 4 Wheel Drive
The 1.5 max travel has everything you would need for a kit except for an adjustable rear track bar and bump stops. I use Teraflex add-on bump stops part #953800 for the front [need 2] and part #1954700 for the rear [only need one, sold in pairs]. For the trackbar, you don't have to get a RK one, any trackbar will work.
Old Aug 4, 2014 | 10:17 AM
SHOELESS's Avatar
Do you think the 1.5 RK kit will work well with stock fenders and 35s assuming the correct wheel back spacing?
Old Aug 4, 2014 | 10:34 AM
TeraFlex's Avatar
Sponsoring Manufacturer
https://www.youtube.com/watch?v=V_Qp7L_eTqU If your planning on running that much weight on the front, I would consider a 3" coil.
