Alternatives to spring clip retainer? No time to order online...
Old Aug 26, 2014 | 08:55 AM
Skumbag's Avatar
Default Alternatives to spring clip retainer? No time to order online...
All,
Is there another option to use to keep my front springs from popping out? I'm headed to Moab at the end of the week and I just got back from a trail locally and found that I'm over flexing and popping springs. I called around to all the local shops and they'd all have to order retainers and it wouldnt get here in time for my trip.
What other alternative means could I use to keep them in? Anything from Home Depot that might work? Bungee cords perhaps?
Old Aug 26, 2014 | 09:17 AM
SpicedCrusher's Avatar
Most online vendors would have them to you by mid-week easy if not sooner
Old Aug 26, 2014 | 09:39 AM
Woody's Avatar
Vet Army
try electrical conduit clamps or call Sierra Expeditions over your way they may have some?
Old Aug 26, 2014 | 09:42 AM
PhxSilver's Avatar
When you see the clips you will be very surprised how small and simple they are. Get some conduit hold downs and fab up your own.
Old Aug 26, 2014 | 09:49 AM
FlexyJK's Avatar
I run the Teraflex front and rear. And honestly its just a piece of metal with a bolt hole in it. And the rear is a big fender type washer that uses the hole in the bottom of the coil perch.
Old Aug 26, 2014 | 10:56 AM
D_engel's Avatar
Large hose clamp threaded under the coil perch and up around the spring. They will still unseat up top, but that is perfectly fine.
