Grinding noise at full turn
Old Aug 27, 2014 | 07:16 PM
robbins84's Avatar
Default Grinding noise at full turn
So today while i was driving around i notice a loud grinding noise when i turned completly to either side i looked and could see anything that appeared to be out of place. Does anyone have any sugestions or ideas?
By the way i am completely stock suspention with 31 bfgs all terains if that helps
Old Aug 27, 2014 | 08:40 PM
tkelly311's Avatar
Grinding as in metal clicking or scraping sound or a high pitched whine sorta sound? Power steering can whine a little at full turn especially if the fluid is below full. Clicking or rattling sound could be ujoints or tires hitting the sway bar, which is likely if your tires are wider than stock. Or it's just a jeep being a jeep.
Old Aug 27, 2014 | 08:45 PM
ZombJep's Avatar
Check to see if you are hitting the plastic skid plate looking thing. If you are, notch it out or just remove it all together. It's useless.
Old Aug 28, 2014 | 01:35 PM
robbins84's Avatar
I have a aftermarket bumper so i dont think thats it i did find a spot on the left side of the sway bar that looks like it could have been rubbed but when i turned the tires they weren anywhere near touching?
Old Aug 28, 2014 | 01:43 PM
Jeepstin12's Avatar
when the wheel is on motion, the tire can "move" a bit. I other words, being a flexible material, with dynamic movement the tire may rub while rolling at the material distorts from its static form. The easiest way? Check for rub marks. If there aren't any, it is most likely joint related. Back the other inquiry. Is it a metal grind? Or a more dead sound, like rubber on metal? Rubber on plastic?
Old Aug 28, 2014 | 06:41 PM
robbins84's Avatar
It is more of a rubber on metal grind it sounds like the tread is catching on something
