spyder or smittybuilt rocker body cladding protection
Old Aug 30, 2014 | 06:25 PM
jeepjkgrrl's Avatar
I'm looking for pics and advice on which is better. Spyder or smittybilt rocker body cladding protection.
4-door
Have rock rails already so no next gen
Old Aug 31, 2014 | 04:07 AM
20JK10's Avatar
I would go with PS. It will at least line up correctly the first time. Plus, made in the USA.
Old Aug 31, 2014 | 12:09 PM
Offroad_Elements's Avatar
Former Vendor
Poison Spyder all the way on these- as noted above they fit better and made in the USA.
Feel free to PM me any time for our forum member pricing
Old Aug 31, 2014 | 08:38 PM
davison0976's Avatar
You know what I never liked about any type of cladding protection? You drill wholes, then you install parallel plate, then water, dirt, you name it, gets in between and stays there, then before you know it the wholes you drilled start to rust.
Old Aug 31, 2014 | 08:43 PM
jaker t5's Avatar
I have the SB cladding and I really can't say anything to bad about them after having them for a couple years , the biggest compliant was the install directions bad , wrong size bolts
Old Sep 1, 2014 | 08:13 PM
smileyz's Avatar
Poison Spyder Body Armor! Get there Rubber Body Armor Liners so WHEN you get dirt and tiny rocks behind it. It doesn't scratch the $h!t out of your paint.
Doesn't the current Smittybilt armor cladding coming in 3 pieces per side? It looks like a royal pain in the a$$ to install and have it all line up together and look right.
Mike K.
Old Sep 2, 2014 | 03:13 PM
jeepjkgrrl's Avatar
Made in America wins me every time!
Old Sep 2, 2014 | 03:17 PM
jeepjkgrrl's Avatar
Mike K.
Thank you so much for that part about the padding, I was judt going to plasti-dip them before the install and then spray paint the holes before I installed
Old Sep 2, 2014 | 04:10 PM
JE8154's Avatar
Get aluminum, not steel and paint it, not plasti dip. Paint all the holes you drill. Skip the rubber padding, you're about to drill 30 holes in the body of your jeep do you really care if you scratch underneath? Silicone along the top seam.
Old Sep 2, 2014 | 05:46 PM
jeepjkgrrl's Avatar
What about Or-Fab's ? They even go further, extend under the fenders, where spyders doesnt
