Best quick discos
Old Sep 2, 2014 | 09:41 PM
jeeptk93's Avatar
Default Best quick discos
Looking for the best quick discos..... whats your best experience with some
Old Sep 2, 2014 | 10:33 PM
lowendrider's Avatar
I have the JKS quicker disconnects. I've had no problems with them..very stout, adjustable, and relatively easy to get on and off.
Old Sep 3, 2014 | 12:08 AM
nthinuf's Avatar
Been running JKS discos for about 6 years. They work fine, no issues at all with them.
The Teraflex discos are fairly popular also, since they have a way to mount them when disconnected instead of removing and storing someplace.
Old Sep 3, 2014 | 05:11 AM
kaptkrappy's Avatar
I prefer the discos that just disconnect from the lower end (joint).
Some come apart at both ends, and even though I've never owned this style, it looks like more work to pull apart and to re-install.
With the bottom only style, you pull the link off the bar pin and stick it on the supplied bracket and your ready to go. Reverse that procedure and your back to normal.
Here's mine.
Name:	Done 2 med.jpg
ID:	574242   Click image for larger version
Name:	Disconnected 1 med.jpg
Old Sep 3, 2014 | 05:57 AM
etl330's Avatar
I have the Teraflex and they work well. this thread might be helpful - https://www.jk-forum.com/forums/sale...ficate-309638/
Old Sep 3, 2014 | 06:37 AM
Dodge4me's Avatar
Here's mine.
What Kind are your's?
Old Sep 3, 2014 | 06:49 AM
Rich6700's Avatar
I never disconnect, antirock sway bar is great.
Sent from my iPhone using Tapatalk . Rich
Old Sep 3, 2014 | 09:17 AM
kaptkrappy's Avatar
[/QUOTE]
Rough Country
Front Sway-bar Quick Disconnects (3.5-6in) for 07-13 Jeep JK Wrangler [1146] | Rough Country Suspension Systems
Old Sep 3, 2014 | 09:55 AM
foley0416's Avatar
Used jks for 3 years with no complaints. Easy to install and remove when needed.
Old Sep 3, 2014 | 04:37 PM
trouty33's Avatar
Not sure about "best" but I did the homemade ones and they work fine.
