Replacement U-Joint D-30 2013 JKU (non Rubicon)
So I have a faulty u-joint after some offroading. Stock axles on a dana 30, non rubicon 2013 JK unlimited. Ordered what I thought was the right one (Spicer 5-760X) but now I have it all apart I go to put the new joints in and it is smaller then the broken one. the one I took out is about 2.5" snap ring to snap ring but the new one is only 2.2". All the online sites say the 5-760X is the right one for a D30 2013 wrangler but it doesn't look it to me. Anyone know the correct part? everything i find on the web says the 5-760X is right for the non rubi (D30) and I definitely have aD30 front axle with stock shafts. the old one has SPR 5182 stamped on it. Here's comparison pic of the two joints.
Also, any bright ideas where I can get one on a Sunday as I need to get stuff back together tomorrow.
thanks, Alan
PS - anyone need a couple 5-760X U-joints?
thanks, Alan
Ok - I know I'm talking to myself. specs and photos on amazon say this is the one i have even though this all says Rubi/D44 everywhere I look. But amazon can get me one to my house tomorrow so I took a chance
Spicer 5-7166X 1350 Series U-Joint
looks like I'll be doing some late Sunday evening installation....... (assuming it's the right size)
continuing my discussion with myself. maybe someone will join me this time........ i replaced this with a Spicer 5-7166X. had to grind a little (red arrow) to get it to fit as it was a little beefier in the body compared to the stock. but the measurements were all the same and it fit. all was good, until a few hours into some offloading last weekend and the loud clicking noise comes back. look at it today and this new U-joint is destroyed - see purple arrow in picture. now am i just unlucky (or just a clumsy driver), is this the wrong part #, installed badly, or do I perhaps have something else wrong that is causing my U-joints to fail? any ideas?
thanks, Alan
2013 JKU stock dana 30 front axle
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578514"/> continuing my discussion with myself. maybe someone will join me this time........ i replaced this with a Spicer 5-7166X. had to grind a little (red arrow) to get it to fit as it was a little beefier in the body compared to the stock. but the measurements were all the same and it fit. all was good, until a few hours into some offloading last weekend and the loud clicking noise comes back. look at it today and this new U-joint is destroyed - see purple arrow in picture. now am i just unlucky (or just a clumsy driver), is this the wrong part #, installed badly, or do I perhaps have something else wrong that is causing my U-joints to fail? any ideas? thanks, Alan 2013 JKU stock dana 30 front axle
makes sense. i'll check out the axle for straightness etc when I get it out next weekend. not sure what else i should check. i guess bent C's could put a lot of stress on a u joint. as could driving like a yahoo :-)
Were the clips seated firmly against the machined face ?
The u-joint shouldn't just fail like that unless a cap backed out.
Next time it's out. You can grind away some of the ear for full circle clips. That or place a small tach weld to keep the caps in place.
2007 Rubicon /2 door/6 speed
