Spod GEN I questions...
Old Sep 6, 2014 | 08:29 PM
ski-YA-later's Avatar
Default Spod GEN I questions...
Like a dumbass I bought a used Spod. From everything I have had to buy for this piece I could have gotten a brand new one. and a gen2 for that matter.
Can someone with a Gen I help me on where to put this wire for the low voltage cut off? I have 1 to + and 1 to the wire harness, do I just ground this one? See pic.
Also- anyone know how i can get these little brackets? Lowes did not have anything that would work. The @ss who I got this from did not include 2.
Ah.. Can't wait to be finished with this stupid thing that should have been done along time ago
ID:	574720Click image for larger version
ID:	574721Click image for larger version
Old Sep 7, 2014 | 01:03 AM
Mark Doiron's Avatar
I wasn't even aware that they had two generations of sPOD.
Regardless, as far as these "brackets" (they're electrical connectors, aren't they?), you might try using just a terminal lug with a screw directly into the sPOD terminal strip.
On my sPOD the width of the dividers along that terminal strip are very narrow, so I put each terminal lug on a bench grinder to flatten the sides just enough to fit it into the slot.
As for where to connect the wire, if no one answers recommend contact sPOD directly. I dealt with them when one of the switches on mine failed and they were very prompt in getting me fixed up.
Old Sep 7, 2014 | 08:08 AM
Thanks Mark. Spod has been really helpful with me too.. I had to send in the bracket for the 2008 and switch it for the 2010. I just didn't want to bother them at 10pm on a saturday.
It is like those connections, but I wanted everything to be uniform on the spod- I guess I am just gonna make it work.
The 2nd gen has the low amp built in, and a single connection for the wire harness- way better. Even when I called spod they felt bad about me getting a gen1.
Sucks!
