Synergy front track bar bracket question
Old Sep 7, 2014 | 08:01 AM
hoghd06's Avatar
Default Synergy front track bar bracket question
Just installed my new track bar bracket. In the instructions it shows mount the steering stabilizer in the top hole shown in picture. However mounting it here puts a drastic angle on the stabilizer. I opted to use the unused hole to the right which is lower and puts much less angle on the stabilizer. Just wondering if this is acceptable or do I need another type of bracket
ID:	574766   Click image for larger version
ID:	574767   Click image for larger version
Old Sep 8, 2014 | 05:27 PM
hoghd06's Avatar
Anyone?
Old Sep 8, 2014 | 05:34 PM
mattyk's Avatar
Veteran: Navy
It's probably set up for the drag link flip
Old Sep 8, 2014 | 05:35 PM
mattyk's Avatar
Veteran: Navy
Or you could loosen the jam but and angle the tie rod upwards which is what I had to do
Old Sep 8, 2014 | 05:47 PM
hoghd06's Avatar
I did Just have the drag link flipped. It seems
To be working ok this way but the instructions show the stabilizer mounted up in the higher
Hole. Just wondering if there's any consequences by mounting it where I did or if it's all good this way.
Old Sep 8, 2014 | 06:57 PM
SoK66's Avatar
Originally Posted by hoghd06
I did Just have the drag link flipped. It seems To be working ok this way but the instructions show the stabilizer mounted up in the higher Hole. Just wondering if there's any consequences by mounting it where I did or if it's all good this way.
When I ran that bracket I used the upper hole. I later got their dedicated stabilizer bracket, which bolts on with the three other bolts & gets the stabilizer parallel with the tie rod.
Old Sep 9, 2014 | 01:22 AM
hoghd06's Avatar
Thanks for the input guys.
