Aftermarket Bumper Aerodynamics Questions!
Old Sep 10, 2014 | 06:51 PM
genrec's Avatar
Default Aftermarket Bumper Aerodynamics Questions!
Hey all, yeah noob here clearly. Got a question regarding aftermarket bumpers and aerodynamics that may translate to MPG's, yeah I dint buy a prius I know. Im really into all the stubby , shorter, smaller bumpers like PS Brawler, EVO, etc..these obviously leave the wheels and wheel wells opened a lot, will this slow you down and give you worst MPG, over say a full almost stock size aftermarket bumper, or no difference?
Thanks! Genrec
Old Sep 10, 2014 | 06:59 PM
jaker t5's Avatar
I really think there wouldn't be much of a difference in aerodynamic when comparing stock to any aftermarket bumper
Now weight would play more of part then aerodynamics
Old Sep 10, 2014 | 07:02 PM
Atlacatl's Avatar
Originally Posted by jaker t5
I really think there wouldn't be much of a difference in aerodynamic when comparing stock to any aftermarket bumper Now weight would play more of part then aerodynamics
Co sign... We drive giant heavy bricks, aerodynamics won't make a difference unless your new bumper has two canoes on either side that lean on the windshield.
Old Sep 10, 2014 | 07:35 PM
Jeepstin12's Avatar
I don't even know how to respond to this one. You drive a brick, on solid axles, unless you best abumper that rins to the ground to create a negative pressure under the chassis, and a scoop to channel air over the hood (think airplane like) you aren't going to see anything different. Maybe 1-2 mpg loss. Maybe......
My mpg went from 17 avg to 14 avg with a stubby, 3" lift, 35" trail grapplers. I have a 2012, auto with 4:10's.
Does that help?
Old Sep 10, 2014 | 07:56 PM
genrec's Avatar
Cool guys..just wondering really..I have 2014 JKU Sport just picked up, getting 20+ mpg stock, mostly hwy driving...goal is 35's on 2.5 of lift with some armor, just kind of wondering about this before deciding on which armor.
Old Sep 10, 2014 | 07:58 PM
Jeepstin12's Avatar
the lift and tires will hurt your mpg more than a bumper. I actually didn't see a difference in mpg after my bumper install. Lift & tires were on for about a year before the bumper.
Old Sep 11, 2014 | 07:48 AM
White Ghost's Avatar
I was getting 18.5-19 with my 14 jku with 3.73 I added 2.5" lift (netted 3 front 2.75 rear) and this rock hard bumper. It dropped me down to 16.6-17.3 then again that was added 120lbs to the front.
Old Sep 11, 2014 | 08:04 AM
Invest2m4's Avatar
Mine went up from 17 to 23. My bumper has a stinger. The stinger actually generates lift, therefore reducing friction on my tires and improving mpg. It also cuts into the air causing it to have a smoother break over my Jeep. I don't have exact numbers, but I estimate my drag coefficient decreased to .30. Pretty solid when considering a Prius is .26.
Old Sep 11, 2014 | 08:36 AM
lkjk's Avatar
as long as you get a front splitter you should be good. I think those are special order though but don't quote me on that
Old Sep 11, 2014 | 08:37 AM
Old Guard's Avatar
Vet Army
