Help identify shock specs
Old Sep 13, 2014 | 03:59 PM
Icepick11's Avatar
Default Help identify shock specs
Bilstien 5100's model number On the front shocks is F4-BE5-E978-T0
Rear F4-BE5-E189-T1
Old Sep 13, 2014 | 04:23 PM
TheDirtman's Avatar
They have a website.
look for a part number on the shock that starts with a 24- or 33-
Old Sep 13, 2014 | 04:28 PM
TheDirtman's Avatar
here is the link
http://cart.bilsteinus.com/pdfs/off-road.pdf
Old Sep 13, 2014 | 04:49 PM
Icepick11's Avatar
Those are the part numbers
Old Sep 13, 2014 | 04:58 PM
Icepick11's Avatar
Any reps on here
Old Sep 13, 2014 | 05:26 PM
meep97's Avatar
What I found on another site while searching the part numbers you listed.
The shock in the photo shows part number F4-BE5-E978-T0
That's Bilstein's old part numbering systems. If you go here:
Bilstein, Innovation and High Quality Since 1873
Generally you can plug in the old part number and it will translate to the new part number.
In your case, that doesn't work. What that means is they are a custom part. Bilstein makes shocks for other manufacturers that are custom lengths/valving.
My bet is that they are an RCD (Race Car Dynamics) Bilstein 5100 series. They buy tons of specially valved shocks from Bilstein.
Your best bet would be to call Bilstein and give them the part numbers and see what they can do for you.
Old Sep 14, 2014 | 07:19 AM
TheDirtman's Avatar
If memory serves me they have a part number stamped into the metal.
Old Sep 14, 2014 | 07:47 AM
jaker t5's Avatar
How about you just measured the collapsed and the extended length to get your travel and then find another shock with that length and find out if it will work for you
Or just measure like I said above and post it and tell us what size lift you have or no lift
Old Sep 14, 2014 | 03:23 PM
Icepick11's Avatar
[QUOTE="TheDirtman;3981228"]If memory serves me they have a part number stamped into the metal.[/QUOTE
He's gonna send me the engraved numbers tonight when he gets off work
Old Sep 14, 2014 | 03:24 PM
Icepick11's Avatar
Originally Posted by jaker t5
How about you just measured the collapsed and the extended length to get your travel and then find another shock with that length and find out if it will work for you Or just measure like I said above and post it and tell us what size lift you have or no lift
If the engraved numbers are no help that's what I'll have him do
