Diff leak after 1310 drive shaft install
Old Sep 14, 2014 | 12:13 PM
TxJeepers's Avatar
Default Diff leak after 1310 drive shaft install
Had a shop install a Coast 1310 front drive shaft on my '14 JKUR automatic. This was a couple months or so ago. I noticed when looking things over that it appeared to leak some fluid. Figured it was related to the install, would wash away and no big deal. Never said anything.
Was looking things over this morning and it appears that leak never went away. Here are some pictures below.
Leak is not enough that I see drops on the ground, but it is all over the axle and clearly has continued.
What do you think? Serious issue? Covered by warranty?
ID:	575619Click image for larger version
