What size wheel spacers would I need?
That's a 33x10 tire? There are differences in actual tire size bettwen mfg's, so it is possible that you won't need spacers, or maybe an extra washer on the steer stops would work.
If you do need to move the tires out, look at any of the 1.50" SpiderTrax type spacers that use two sets of bolts. (if you go with 1.25" ones that Teraflex makes, be sure you check the fitment and trim the bolts if needed!!!) Try and stay away from the thin spacers that sandwich between.
