Lifetime warranty to replace bent axle C ?
Old Sep 15, 2014 | 06:01 PM
JayswranglerX's Avatar
Default Lifetime warranty to replace bent axle C ?
Anyone had this done yet?
I think mine is bent a bit and causing some weird tire wear and vibes
Sent from my LG-LS980 using JK-Forum
Old Sep 15, 2014 | 07:10 PM
KCCO JK's Avatar
I don't even know if that's possible. I mean, I'm sure it is.. The axle is a covered item on the vehicle. But.. Jeep without a doubt would make that incredibly difficult to get done. How did you do it? I would think Jeep would take the "you were reckless, abused, or neglected it" route with that one..
I would find out whatever dealership in your area has the absolute best track-record with jeeps, and go from there..
Old Sep 15, 2014 | 07:18 PM
nthinuf's Avatar
I think that they will look at the lift and tires, then walk away laughing. But give it a shot. What's the worst that can happen, they say no? Or flag your jeep and void the warranty...
Or, maybe they'll give you a deal on offset bj's or something. Depends where you go and who you get.
Old Sep 15, 2014 | 08:55 PM
kjeeper10's Avatar
Vet Army
A Alignment will show a bent C.
Off set ball joints can fix camber issues FYI
2007 Rubicon /2 door/6 speed
Old Sep 16, 2014 | 03:48 AM
Not sure how it happened...probably these craptastic Michigan roads with the mini speed bumps everywhere.
This Jeep never sees more than the pavement....that's what the YJ is for!
so can't be bent from abuse.
Old Sep 16, 2014 | 05:32 AM
Invest2m4's Avatar
Get an alignment and go from there. Be aware that your camber is most likely out of spec, which is 100% normal for the JKs. I'd say up to -.9 is within spec. You'd have to have a REALLY bent C to cause tire wear issues. Tire wear problems are more likely due to other alignment factors such as toe, or bad ball joints. Incorrect tire pressure is another one that will do it. If you didn't chalk test your tires from the start, you may have been wearing the tires unevenly.
Old Sep 16, 2014 | 07:14 AM
Alignment scheduled for tomorrow. I'll check the BJ's after work.
Thanks for all the help guys I will report back after the alignment is done
