Do I Need Different Bump Stops for 1.5" Front Coil Spacer Lift?
2014 JK with the spare tire removed, bushwacker flares and 35" tires.
The rear is about 1.5" higher than the front with the spare removed and I want to level it out. Got the 1.5" spacers that I'll be installing (front only) and I can't find anywhere if I should leave the factory bump stops or change them out.
Also, will the factory brake lines be okay with just a 1.5" lift in the front?
Can anyone shed some light on this for me?
Thanks ahead of time!
Think your bump stops should be ok unless there are simply worn out.. but new and slightly extended stops might suit this.. I tend to think if one lifts more than 2 inches.. the stops need to be added..
As for the brake lines.. I would do it.. but it just depend on the shocks.. seems the Skyjackers on our jeep stress the lien when the jeep is lifted.. thus new relocation brackets are going to be installed shortly.. yet this is just for the rear.. didn't notice any stressing on the front lines..
Unless you are concerned about over compressing a cheap spring. I have seen three RC springs sag the morning after lots of flex.
2014 JK with the spare tire removed, bushwacker flares and 35" tires. The rear is about 1.5" higher than the front with the spare removed and I want to level it out. Got the 1.5" spacers that I'll be installing (front only) and I can't find anywhere if I should leave the factory bump stops or change them out. Also, will the factory brake lines be okay with just a 1.5" lift in the front? Can anyone shed some light on this for me? Thanks ahead of time!
