2.5 Teraflex spring lift
I just had a 2.5 spring lift from teraflex and running 17s and 35s. It drives like a 98 Dodge 2500. It's follows every little dip in the road. You literally have to DRIVE it to keep it straight. I just replaced the whole tie rod today because I snapped the adjuster when trying to get the toe in. Got the toe in between 1/8 and a 1/16 today and still the same result. It's aggravating because I originally planned on doing 35s and flat fenders and no lift because it actually drove pretty good with the 275/70/18 and spacers it had on it before. Anything else I might need to put on it to try and correct the wandering?
My teraflex 2.5 yielded about 3" after I installed it. It took me a bit to get everything dialed in, go through and measure to see how much everything is off. My front axle was shifted a bit so I added an adjustable track bar and that helped with the pulling but as with bigger tires that was expected. With these kits certain things aren't necessarily needed; adj track bar and control arms but sure are helpful when trying to get it to drive properly. I'd start with a adj track bar, get an alignment, and go from there.
Options for correcting low caster are Cam Bolts, Drop Brackets, Longer/Shorter fixed length control arms, Adjustable control arms. They all have positives/negatives, so do a little research before pulling out the credit card.
Do you have an understanding of what caster is? Or that it decreases as the lift height increases? There is some info in the FAQ's and Thought on Lifts threads stuck right at the top of this modified area.
2007 Rubicon /2 door/6 speed
