Jks discos
Old Oct 3, 2014 | 04:53 PM
Bpash2096's Avatar
Default Jks discos
Anyone had any issues with these. Mine have started to make clunky sounds while driving. Think the bushings may have gone.
Old Oct 3, 2014 | 05:09 PM
jadmt's Avatar
JK-Forum Ambassador
have you greased them? also retorq the bolts.
Old Oct 3, 2014 | 05:11 PM
PG-JKU's Avatar
Check the tightness of the studs. The top one on my driver's side gets loose once in a while and needs to be tightened up. Also check that they are greased up. I found that putting the cotter pin through the hole without the link then grabbing it with a pipe wrench to hold it lets me put a lot more torque on it.
