Rancho RS9000XL shocks: I'm a believer
Old Oct 6, 2014 | 07:16 PM
20JK10's Avatar
Default Rancho RS9000XL shocks: I'm a believer
So I finally got around to getting my new Rancho RS9000XL shocks installed. Let me first say that they are made in the USA, stamped right on the shock body. And whoever designed the front shocks must have an auto mechanic background. There is a little nut on the top of the shock body you can hold with a wrench to help keep the shock in place when tightening down the stud.
I'm still playing around with the settings, but I currently have them on setting four. I could immediately feel that they were softer then the Bilstein 5100 I previously had. For those that live in pothole states, they do seem to absorb the bumps better.
Off to mail in my rebate.
Old Oct 6, 2014 | 07:26 PM
Offroad_Elements's Avatar
Former Vendor
I've got a set on my JK and TJ! Commute and conquer!!
Old Oct 6, 2014 | 09:12 PM
ShiftKnowledge's Avatar
I gotem, totally satisfied and set on 5
Old Oct 7, 2014 | 12:58 AM
Mark Doiron's Avatar
Originally Posted by 20JK10
.... And whoever designed the front shocks must have an auto mechanic background. There is a little nut on the top of the shock body you can hold with a wrench to help keep the shock in place when tightening down the stud. ....
Not to cast disrespect on the auto mechanics out there, but any decent engineer should take maintainability into consideration during the design process. The engineers for the Bilstein 5100s should take note of how to properly design a shock.
Old Oct 7, 2014 | 02:23 AM
carlojp's Avatar
If you change the settings of the RS9000XL, does the height change also or just the softness?
Old Oct 7, 2014 | 02:59 AM
teejayone's Avatar
Just the softness.
Old Oct 7, 2014 | 03:44 AM
mpkelley20's Avatar
Been running mine for about a month now. Had bilsteins for almost 5 years. What a difference! I'm running mine on 2 just to enjoy the soft ride for now. I'll probably settle in around 4 when I'm ready to reduce the body roll a bit. I tried them on 9 and it was a brutal ride. Lol. I think, based on all the settings I've tried, the bilsteins are probably close to a 7 on the ranchos. While I thought I liked that stiffness, not true any more.
Old Oct 7, 2014 | 08:38 AM
Rancho's Avatar
Sponsoring Manufacturer
Thanks all!!
To those popping in, here is the info on Shocktober.
Rancho Suspension: SHOCKTOBER® PROMOTION
Old Oct 7, 2014 | 08:53 AM
20JK10's Avatar
It's just too bad my white Rancho steering stabilizer doesn't match the silver shocks. Oh well.
Old Oct 7, 2014 | 08:54 AM
Rancho's Avatar
I know.... they changed that a while ago.
