Using programmer before/after inspection
Old Oct 12, 2014 | 02:21 PM
Matthewd5's Avatar
Default Using programmer before/after inspection
Hello
I need to take off my 37's and put on my factory wheels/tires to be able to pass inspection
My question is, after I put on the much smaller factory tires, should I go in and reprogram it for the short ride to/from the inspection shop?
Is there anything specific to change programming wise to have it pass inspection?
Matthew
Old Oct 12, 2014 | 02:47 PM
Rebar-7's Avatar
Originally Posted by Matthewd5
Hello
Matthew
Make sure you post a pic of your rig with the stock wheels on Matthew..
Sorry can't help with your question..
Old Oct 12, 2014 | 05:55 PM
agentjohnson's Avatar
Hello
Matthew
Unless you are using your programmer to turn off O2 sensors for catless downpipes or anything like that the only problem I can forsee happening is an out of range speedo, and different shift points. It will likely just be a rough ride more than something that can cause an inspection failure.
Old Oct 12, 2014 | 06:43 PM
Matthewd5's Avatar
Thanks for the info
I have the six speed manual, I only use the programmer for speedometer and gear ratio
Matthew
Old Oct 12, 2014 | 09:44 PM
Thanks for the info
Matthew
You will be fine.
