Trouble Reaching Pedals ?
Old Oct 16, 2014 | 08:54 AM
htm7765's Avatar
Default Trouble Reaching Pedals ?
Looking for a solution to a problem, my wife is having trouble reaching gas pedals in my jeep, she has short legs I tried stretching her did not work..,,, I thought of putting a block on the floor but if I drive it would be in my way,,,, so I only have two ideas first do not let her drive.. As much as I love driving my jeep a break once in a while is needed, other option trade her in for a taller one !!! Please help don't want to use option two !!!!
2011 2dr Sport manual trans
Old Oct 16, 2014 | 09:26 AM
pjmjk's Avatar
even with seat adjusted all the way down?
Old Oct 16, 2014 | 09:28 AM
Grant09's Avatar
Maybe you could put a Jeep sticker on the side? Also helps her getting into the Jeep after a lift kit install.
Old Oct 16, 2014 | 09:30 AM
JE8154's Avatar
My girlfriend is 5'2" puts the seat up and she can get the clutch to the floor.
Old Oct 16, 2014 | 12:11 PM
D3ADLY's Avatar
Maybe you could get someone to cut and re-weld the pedals out several more inches. My dad had this done with a gocart when I was little because I couldn't reach the pedals. I don't see why it wouldn't work with the jeep. You'll just have to sit back maybe a few inches father than you normally do which really is no big deal at all.
Old Oct 16, 2014 | 04:21 PM
htm7765's Avatar
Originally Posted by Grant09
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=580085"/> Maybe you could put a Jeep sticker on the side? Also helps her getting into the Jeep after a lift kit install.
Yes the lift kit is in the garage that's a whole other issue... Like the boot idea could be multi purpose ! !!!😀
Old Oct 16, 2014 | 04:27 PM
htm7765's Avatar
Butt seriously she is short 5ft on a good day seat is all the way forward and all the way down she can reach the pedals it's more that she has to keep her foot elevated to keep pushing the has pedal brake and clutch is fine once on the highway the cruise helps I will take a look at the gas pedal and see if it can be modified.. Thanks keep the ideas coming 👍
