New coils and 35s bumpstops question
Old Oct 22, 2014 | 06:41 PM
Derrick_Merwin's Avatar
Default New coils and 35s bumpstops question
I have a 2dr jeep jk that is pretty light not a lot of added weight from bumpers or armor I'm going to be putting some 18,60 coils and possible front coil spacers to make my jeep level and 35" tires on wheels with 4.5" backspacing i also have flat fenders I was just wondering if anyone is running anything like this and knows what length of bumpstops I should get for this setup?
Old Oct 22, 2014 | 07:07 PM
fultonromero12's Avatar
I ran almost the exact setup that you are describing for a while with stock bump stops. No issue. Never hurts to upgrade if you plan on going to a bigger lift in the future but I think it will work just fine as in. Who told you you needed one?
Sent from my iPad using JK-Forum
Old Oct 23, 2014 | 03:11 AM
Originally Posted by fultonromero12
I ran almost the exact setup that you are describing for a while with stock bump stops. No issue. Never hurts to upgrade if you plan on going to a bigger lift in the future but I think it will work just fine as in. Who told you you needed one? Sent from my iPad using JK-Forum
No one did I just assumed I would need them and I was thinking of getting the kit from synergy that flips the steering stabilizer up and that says you need atleast 2" bumpstops but I probably just won't do that until I lift it
