Spare tire carrier 35"
Old Oct 27, 2014 | 12:06 PM
snosurferjeep's Avatar
Default Spare tire carrier 35"
Looking for a good relocation bracket for 35" duratrac spare on my stock carrier.
Old Oct 27, 2014 | 12:18 PM
JE8154's Avatar
Are you sure you even need one? I ran a 35" spare on the stock carrier for a while.
Old Oct 28, 2014 | 09:44 PM
Asinine's Avatar
Ditto. I run a Nitto 35" on the stock carrier and it's fine. I did the radiator hose trick to keep it snug to the tailgate, but that's it.
Old Oct 29, 2014 | 01:18 AM
Dr. Satan's Avatar
My 315/70 17 duratrac did not even come close to fitting on my stock carrier with the stock bumper. I have an aev pintler wheel 5.2 backspace. I had a generic bracket that moved the wheel up maybe 2" and out 2" but then it stuck out too far for my taste even with extended bumpstops. I ended up buying just the teraflex tire mount, it allowed me to adjust the tire right against the factory bumpstops.
Depending on the backspace of your wheel you may be able to get away with a standard bracket (like I had originally) like many manufacturers offer for around $40. Smitty, teraflex and others offer them, the expedition one bracket looks nice but is expensive for a spacer. And if any standard spacer doesn't give the fit you want it is nonadjustable.
Old Oct 29, 2014 | 05:45 AM
Invest2m4's Avatar
Odd. I had the same tire on a 4.5" BS wheel and it wasn't even close to not fitting. I would have had no problem with the AEV wheel either. The Duratrac is barely 34".
Old Oct 29, 2014 | 06:06 AM
JE8154's Avatar
It's the wheel backspace that's going to kill you. I had a 35 toyo mt on the stock carrier with the stock bumper and it just snugged up on the bumper.
Old Oct 29, 2014 | 08:36 AM
Dr. Satan's Avatar
Yeah I see guys all of the time saying they put their whatever rim and tire on the stock carrier with no spacers. Didn't even come close to fitting on mine. Ordered my jeep new in 2007. No damage ever. Tailgate and bumper have never moved since the day I bought it.
Bought the pintlers and duratracs from a guy on Craig's list who had sold his jk. Guy threw in the basic spare tire lift bracket with the wheels and tires. He said the spare didn't fit on his jk stock carrier without the bracket. And he was right.
Old Oct 29, 2014 | 01:13 PM
mpthompson84's Avatar
I ran my 315 Duratrac on my stock carrier for well over a year with zero issues (17" wheel 4.5 backspace).
I wouldnt have done it with a heavier tire (ie nitto/toyo) but the Duratrac is alot lighter than most 35's and fit great with zero damage to the gate (no signs of wear either)
Old Oct 29, 2014 | 01:31 PM
idiotec's Avatar
I run 35's on the stock wheels and the spare would not fit. I use the Expedition One adapter. Works great, and if you look at the design, is not something that will ever bend or break.
Old Oct 29, 2014 | 02:05 PM
jeep-creep's Avatar
I have a 35 on my stock carrier with a spacer and it fits however, it's starting to flex on the tailgate where the carrier mounts. I can hear the metal flexing over bumps. What's this radiator hose trick?
