Tire size on stock Moabs ?
Old Oct 29, 2014 | 08:47 PM
DEADRABBIT31's Avatar
Default Tire size on stock Moabs ?
I'm due for new tires and have decided on 285/75/17 KM2's . My question is can I mount that size tire on my stock Moab rims without using spacers ?
- 2013 Rubicon with stock suspension - Any help would be greatly appreciated !
Old Oct 29, 2014 | 09:20 PM
bthomas's Avatar
FWIW, I had 285/70/17 KM2's on stock Moabs, they fit just fine. I have Spydertrax spacers, but I'm not 100% sure they were needed to prevent any rubbing for that size tire, I put than on as soon as I got home from the tire shop and have never taken them off. That size is only slightly larger than a stock Rubi KM if I remember right. Hope this helps.
Old Oct 30, 2014 | 04:41 AM
jadmt's Avatar
JK-Forum Ambassador
I needed spacers and used spidertrax 1.5" on my 14 rubicon. I ultimately ended up going to a wider rim with less backspacing. here is the comparison. they are a lot bigger then stock. The ones mounted on jeep are 275/70-17. They rubbed on sway bar and very close to the driver side rear lower control arm without spacers.
Old Oct 30, 2014 | 05:32 AM
Chadam's Avatar
I put 315/70 17 on stock rims with 1.5" spacers and 2"bb and they work great! Trimmed the air dam that's it
Old Nov 1, 2014 | 02:07 AM
Thanks for the info everyone. I might just hold off another month and get the AEV wheels with new rubber all at the same time so there's no issues.
Old Nov 1, 2014 | 04:05 AM
jadmt's Avatar
JK-Forum Ambassador
If you are going to play in the rocks I would skip the AEV's if you are thinking of getting pintlers. If I had to do it over I would go another route.
Old Nov 1, 2014 | 06:28 AM
BCT's Avatar
BCT
If you go AEV wheels... The Savegre's are strong and will not have cracking issues and look great! Just my .02
