Mounting 33 inch spare
Old Nov 3, 2014 | 04:32 PM
htm7765's Avatar
Default Mounting 33 inch spare
Know I can just swap it out but before I waste a time doing that I figure someone has the answer to this simple question I upgraded my tires to 33x10.5 I want to put on the spare but I have read that nothing more than a 32 inch tire, so do I need a relocation bracket and will my tailgate handle the extra size tire ?????
Old Nov 3, 2014 | 04:35 PM
fultonromero12's Avatar
I've been running a 285/75/16 (33") on my stock carrier with no issue for 2 years. I wouldn't try anything bigger.
Sent from my iPad using JK-Forum
Old Nov 3, 2014 | 04:42 PM
htm7765's Avatar
Originally Posted by fultonromero12
I've been running a 285/75/16 (33") on my stock carrier with no issue for 2 years. I wouldn't try anything bigger. Sent from my iPad using JK-Forum
Did you use a relocation bracket ?
Old Nov 3, 2014 | 05:50 PM
No. Just removed stock tire and mounted new wheel.
Old Nov 3, 2014 | 07:08 PM
PG-JKU's Avatar
I have a 33x12.5x15 on my spare mount. Tire and alloy wheel combo is lighter than stock so I have been fine so far.
Old Nov 3, 2014 | 09:49 PM
headrock's Avatar
MBRP makes a good reinforcement bracket kit, it's worth getting just as a precaution. I have it and my spare is at 82 lbs on the stock carrier with no problems.
Old Nov 4, 2014 | 06:06 AM
jadmt's Avatar
JK-Forum Ambassador
34" fits fine on stock mount. might have to either lengthen or shorten the rubber bumpers depending on rim backspacing.
