LOD Slider Install - Did I screw it up?
Hi there,
When tapping the holes in my frame rails, I slowly and carefully spun the tap through the hole, then ran a bolt through to make sure the threads were clean and clear. I did this on all the holes prior to installing the sliders. When I actually put the sliders on, each bolt felt like it really bit well, and I tightened them down pretty snugly with a 3/8" ratchet. They feel extremely solid. BUT:
A guy I know, who admittedly knows more about these things than I, told me that I should have turned the tap 1/2 turn, then backed out 1/4 turn, the entire time, and that by just turning the tap in, I created looser threads. So, did I mess it up?
I did learn 1/2 in, 1/4 out 50 years ago, and that's how I personally tap a thread. But, I've seen it done both ways. Successfully. As previously mentioned, it's to clean out the debris as the tapping progresses.
Hi there,
Not really. Just make sure you get the correct sized drill bit and tap. I also added a step between my first pilot hole (1/4") and the final hole size, just to move up a little slower. Not sure that's necessary.
Get a buddy to help you just because they're heavy. It took me and my dad 2 hours, and we weren't rushing.
. Any issues installing? Any pictures of them installed.
